Hi guys!
Last time, when i had a problem with programming I got quick and good answers here, so i thought I would share one of my other problems here.
So, I have a task, which for the upper level IT High School exam.
I have to read data from a txt file, into arrays.
program eutazas;
uses crt;
var i,j,n:integer;
	megall:array[1..2000] of integer;
	datum:array[1..2000] of longint;
	kotojel:char;
	ido:array[1..2000] of string[4];
	azon:array[1..2000] of longint;
	tipus:array[1..2000] of string[3];
	lejarat:array[1..2000] of longint;
	szkoz:char;{szokozok beolvasasa}
	f:text;
procedure beolvasas;
var i:integer;
begin
assign(f,'utasadat.txt');
reset(f);
for i:=1 to 2000 do
readln(f,megall[i],szkoz,datum[i],kotojel,ido[i],szkoz,azon[i],szkoz,tipus[i],szkoz,lejarat[i]);
close(f);
{szamlalas}
j:=1;
repeat
if azon[j]<>0 then inc(n);
inc(j);
until azon[j]=0;
end;{beolvasas}
This is(a part of) my code.
0 20190326-0700 4170861 NYB 20190404
And this is one line from the database txt file.
I try to read every part of the line into different arrays.
For the date and time(20190326-0700) first i used a string[13] array, but in a later task i had to use only the date part of it, so i had to make it a longint of array, with seperating the date and time.
I used longint for the date part of it, a char for the '-' mark, and a string[4] for the time. But after that, it compiles, but when I try to run it I get Runtime Error 106(non-numeric value is read from a text file, and a numeric value was expected).
Maybe the way i try to read it parts is messed up already. If thats the case, can anyone recommend me another way, to make it posibble.
I have to use arrays, and it would be too much hassle to make new types, because the time for the exam is kinda short.
Thank for any help in advance!
Ps.: Oh, and sorry for the strange array names. They make sense in my language.
It looks to me like when you're parsing the date, the program doesn't stop at the "-", so it's trying to read all characters until the next space as a number, and complaining about the dash. You'll need to parse the whole section as a string, and then take the first 8 characters and make the long out of that.
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
Sooo, for first i should read it as i did before, with string[13], and after that, take the string apart? You look like you know what youre talking about, but I dont reall get it.
Yep, that's basically it. You'd end up with string[8] + string[1] (the dash) + string[4], and then turn them into whatever numeric data types you need.
Network:
And i should use val() for that right? How exactly should i do that?
I'm not well versed in the FreePascal, but according the The Google, there is a "StrToInt" function that looks like it would do what you need, but it looks like "Val" would also work (just a bit more complicated).
Network:
The code screams for use of record:  https://wiki.freepascal.org/Record
Use just one array , something like
type
	TfileRecord = record
		megall: integer;
		datum,lejarat,azon: longint;
		kotojel:char;
		ido:string[4];
		tipus: string[3]
	end;
var  myLines : array [1..2000] of TfileRecord;
myLines[1].tipus := "123";
