Hi guys, so a month ago i decided to switch from a single monitor to a dual monitor setup so i picked up two used dell P-series monitors a 22" and a 24" and ever since then all hell broke lose, any time i connect both monitors and start running programs on both. my computer shuts down suddenly and restarts.
For example if i full screen a youtube video on the 22" and browse the web on the 24" the computer just restarts, no error messages or anything. if i disconnect the second monitor and only use the 24" it runs fine, and gaming is completely out of the question.
So i was thinking it could be a PSU issue but a PSU would shut down with one or two monitors, then i thought maybe its a GPU issue and i am running out of GPU Memory since its a 1GB card but i am not getting any memory errors. i've already updated the GPU drivers to the latest stable version but i still can't figure out the source of the issue.
My setup is i7-950, AMD Radeon 7770 (Note that both monitors are connected via HDMI to the GPU), Thermaltake 730W.
I Listen. i Observe. I Learn. I make my own decision
https://linustechtips.com/topic/1193677-sudden-shutdowns-and-restarts/
It is more continous load on the gpu so... Maybe the 7770 developed an issue over time?
Did you try switching the ports round or just using the dell? Are there any other options to use other ports to try out?
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
yeah probably one  of the ports is short circuiting
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
Just now, Hammez said:
but why would the whole pc restart if it's just a gpu port short circuiting?
because it temporarily shorts out the gpu causing a shutdown similar to when your overclock has gone too far
well the card has very little in the way of ports it has 1 HDMI 1 DP 1 DVI. so i have an (HDMI to HDMI) and (DP to HDMI converter for the other port) also the cables are new unless they shorting from the head of the connector next to the body of the case
which of these ports are u using?
