3950x Cooling
Go to solution Solved by Guest,
I'm using an NH-U12A on mine. It's fantastic.
Any reasonably chunky air cooler should be fine. IIRC @Den-Fi has a 3950X on water and one on air, he can give solid recommendations 👌
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/1193421-3950x-cooling/#findComment-13593985
The two I've heard being used on this particular CPU are the NH-D15 and NH-U12A.
Really comes down to which is cheaper, as they both perform similar and the difference is marginal from what I understand. Never tried them personally as I have the same CPU, but I use an AIO.
https://linustechtips.com/topic/1193421-3950x-cooling/#findComment-13593996
33 minutes ago, Chin_077 said:
Hey I am going to buy to 3950 but I don't want water cooling.
Can I just use a good air cooler? I am not going to overclock or anything.
If the air cooler is OK what cooler do I need to pick for the best cooling?
Cheers
I would recommend an AIO liquid cooler with anti-leak technology, leaks on AIOs in general are very rare, and the only main concern would be if your case supports the radiator (need at least 240mm radiator support for proper cooling, the 120mm ones are not that effective even when compared to decent air coolers).
I would recommend DeepCool's Neptwin air cooler which is compatible with the AM4 motherboard socket mounting system (used by the Ryzen 3950X):        https://www.newegg.com/deepcool-neptwin-rgb/p/N82E16835856119?Item=N82E16835856119&nm_mc=AFC-RAN-COM&cm_mmc=AFC-RAN-COM&utm_medium=affiliates&utm_source=afcPCPartPicker&AFFID=2558510&AFFNAME=PCPartPicker&ACRID=1&ASID=https%3a%2f%2fpcpartpicker.com%2fproduct%2fVmMwrH%2fdeepcoolneptwinrgb565cfmcpucoolerneptwinrgb&ranMID=44583&ranEAID=2558510&ranSiteID=8BacdVP0GFsKMSuydy3GLWPOTdxPmTmlg
Hope this information post was helpful  ?,
        @Boomwebsearch
https://linustechtips.com/topic/1193421-3950x-cooling/#findComment-13594079
Cheers
After seeing a few builds and results with different coolers, it seems like the overall trend is it doesnt run quite as hot as everyone initially thought it would.  I would imagine the mid to high range noctuas and bequiets could handle it (well the high range def can, the mid range should)
El Zoido:  9900k + RTX 4090 / 32 gb 3600mHz RAM / z390 Aorus Master
The Box:  3900x + RTX 3080 /  32 gb 3000mHz RAM / B550 MSI mortar
https://linustechtips.com/topic/1193421-3950x-cooling/#findComment-13594101
