Budget: no more than 1k usd
Country: u.s
usage: mostly gaming and having alot of chrome tabs open
current list:
cpu: ryzen 5 3600
gpu rtx 2070
psu: need help!
motherboard: help!
ram: 2x8gb tridentZ rgb series
case: help!
ssd: 256 gb m.2 samsung pm 961
hdd: seagate barracuda 1tb (2016)
cpu cooler: help!
i need help choosing a psu,motherboard,a cpu cooler, and a case if i need to change anything let me know
https://linustechtips.com/topic/1193180-need-help-on-pc-build/
MSI B450 MAX board
make sure your RAM is 3200mhz CL16 or 3600mhz CL16, CL18 won't be faster than cheaper RAM
NR400 or NR600 for the case, has the best in class airflow
unless you're doing minecraft ray tracing the RX 5700/XT is a better value GPU
what's your monitor resolution/refresh rate?
https://linustechtips.com/topic/1193180-need-help-on-pc-build/#findComment-13592168
This is close as I could reasonably get it with a X570 board for future upgradability.
Like @boggy77 mentioned the 5700XT is the better card. Now if you have a microcenter near you and can save some money on the CPU I'd highly recommend upping the SSD size to 500GB (Crucial P2 or P1 fpr ~$65-70) and second getting a 3600MHz/CL16 ram kit (~$78)
https://linustechtips.com/topic/1193180-need-help-on-pc-build/#findComment-13592171
2 minutes ago, Streetguru said:
MSI B450 MAX board
i have a 2560x1080 ultrawide 200hz monitor
https://linustechtips.com/topic/1193180-need-help-on-pc-build/#findComment-13592179
This would be an B450 alternative with faster ram with better timings as well, a faster NVMe 1TB SSD (alternatively 500GB SSD + 2TB HDD) and some money left over for a different case/additional fans/whatever - as of right now the better machine, but your only upgradepath would be a Ryzen 3900X (12-core/24-thread) CPU as B450 won't support upcoming Ryzen 4000 CPUs.
https://linustechtips.com/topic/1193180-need-help-on-pc-build/#findComment-13592283
stuff is cool. stuff that has fancy lighting is cooler. stuff that has fancy lighting and works is the coolest.
i game so i know a bit abt gaming tech, not much abt professional tech.
writing this as i finish a 3 hour D2 sesh so excuse anything wrong.
https://linustechtips.com/topic/1193180-need-help-on-pc-build/#findComment-13592326
