Hello everyone,
I want to build a mITX gaming PC and this requires of course components. I want to game on high setting in a small form factor and have a quiet system in addition to this it needs to be futureproof these are the components I have selected up until now see all the components at this link; http://tweakers.net/gallery/547915#tab:wenslijst
Processor;
- Intel i5 4670k
Processor Cooling Unit
- Cooler Master Seidon 120 V
Videocard
- Gigabyte GVR928XOC-3GD-GA
- MSI Radeon R9 280X GAMING 3G
HDD
- Seagate Barracuda 7200. 14 ST1000DM003, 1TB.
PSU
- Seasonic M12II 620W.
SSD
- Crucial 2.5'' M500 120GB
RAM
- Crucial Ballistix Tactical BLT2C4G3D1608ET3LX0CEU
Motherboard
- Asus Z87i-PRO
- MSI Z87I Gaming AC
Case
- Fractal Design Node 304.
I have listed some components twice because I still do not know which I should choose. Therefore advice is very much appreciated.
If you have other recommendations I most certainly would like to know them,
David.
https://linustechtips.com/topic/119310-help-for-mitx-build/
There is no such thing as futureproof...
Other than that it looks decent.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/119310-help-for-mitx-build/#findComment-1590481
Hello everyone,
Processor;
- Intel i5 4670k
Videocard
HDD
PSU
SSD
RAM
Motherboard
- Asus Z87i-PRO
Case
David.
The Seidon will probably be the loudest component in there. I would much rather go with air cooling in a node 304.
 I would go for the MSI GPU as well because the Gigabyte card might be choked due to the grill not going all the way across. Both are great super quiet and cool GPUs.
And are you sure you want to OC your CPU? CPU OC is something i've noticed a lot of people don't actually end up doing because it's not as easy as just OCing your GPU.
"Common sense is not so common." -Voltaire
https://linustechtips.com/topic/119310-help-for-mitx-build/#findComment-1590488
Thank you all for your comments, So whether I choose the Gigabyte or the MSI I will get roughly the same results, And for Mobo the Asus (but why?) and when a consider OC'ing as a must is the Mugen 4 pcgh edition a good alternative for the Seidon 120 V?
https://linustechtips.com/topic/119310-help-for-mitx-build/#findComment-1590559
