Hello,
My computer specs are as followed
Ryzen 3700
Cooler Master Master Liquid ML240L
ASRock X570M Pro4 Micro ATX
G.Skill Trident Z RGB 32gb (4 x 8GB)
Samsung 970 500gb M.2
EVG G5 750W 80+
I have a known good ethernet cord plugged directly form my router into my computer. When i boot and install unraid I get a IPv4 address that starts with 169 and no IPv6. From my research i find that this could be a issue with how the computer is getting internet. I booted into the bios and updated the bios. I do not see any setting in the bios itself for turning off and on the lan card.  So really there is no way for me to confirm that this machine is receiving internet as there is no OS installed. I am attempting to just use unraid.
My home internet is a double nat but i have a static external. Could this be what is causing the issue installing unriad?
I understand that this is a very specific question just really not sure where els to go with it. Thanks in advance
https://linustechtips.com/topic/1192878-need-help-installing-unraid/
probbly is apipa address, means it can;t get a ip via dhcp like it should be able to.
What ais your network setup? Do you have a dhcp server?
Try setting a static ip on unraid.
