Budget: about 1100$, but I can add some more
Country: not the USA, I'm sorry for my bad English
Games, programs or workloads that it will be used for: 1080p 60fps games and light video and photo editing
here is what I'm thinking about, my only concern is the ram speed and the CPU cooler because I am going to overclock in the future:
Ryzen 5 3600 4.20
stock cooler
2X8GB DDR4 3000Mhz
Asus B450M-A
RTX 2060 Super 8GB
1TB hard disk
240GB SSD
Antec 550w
and the case is the Antec NX600
I will be very thankful if you will help me.
the price of this in my country is about 1254$
https://linustechtips.com/topic/1192362-help-me-thx/
What country exactly are you in? What currency do you use? If supply is limited in your country, can you import from anywhere with reasonable prices? It'd be best to use PcPartPicker to compile a list so we can see the exact components.
Some thoughts on what you've posted so far:
- Ram is fine, 3200MHz and above would be great though
- the motherboard is not optimal and I'd highly suggest getting a better one. You can check the LTT motherboard tier list for more info
- what SSD model exactly?
- what PSU model exactly?
https://linustechtips.com/topic/1192362-help-me-thx/#findComment-13586241
