Im in the process of getting the parts to build my first PC and i figured that if I were going to do it I would do it right ( In this case doing it right costs 3,500 US dollars) The list of parts I'm using are...
Rig
GPU: 2 EVGA SC gtx 780 TI's w/ ACX cooler
CPU: Intel 4770k
Motherboard: ASUS Maximus VI Extreme
Memory: 16GB Corsair vengence Red DDR3 RAM
PSU: Corsair ax 860w
SSD: Samsung 840 evo 120 GB
Hard drive: 1TB WD blue
CPU Cooler: Corsair h100i + 2 Corsair SP120 fans
Case Fans: 3 Corsair AF 140 Red Led fans
Case: Fractal Design Define R4 windowed (Black)
Peripherals
Monitor: ASUS VG248QE 24" (might get 2 more to have surround)
Keyboard: Razer Deathstalker Ultimate
Mouse: Razer Naga 2014
Headset: Razer Kraken 7.1
Microphone: Rhode Podcaster
Microphone arm: Rhode PSA1 swivel arm
Shock mount: Rhode PSM 1
So tell me what you think and leave suggestions thanks!
Sorry didnt have use! gaming, recording, editing HD video
https://linustechtips.com/topic/119218-beast-first-build/
Razer is trash. Consider superior mouse, keyboard, and headset
System Specs - CPU: i7 4770K - RAM: 8GB(2x4GB) Vengeance Pro - Motherboard: Maximus VI Gene - Case: Modded PowerMac G5 - CPU Cooler: H100i - PSU: AX860i - SSD: Samsung 840 Series 120GB and Kingston V300 120GB - HDD: Seagate Barracuda 1TB - Graphics Card: 2x GTX 780 - Case Fans: SP120s and Spectre 140s - Headphones: HD700, Alpha Dog, SE215
Sony A7R w/ Zeiss 55mm F1.8
https://linustechtips.com/topic/119218-beast-first-build/#findComment-1589179
looks fine
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
https://linustechtips.com/topic/119218-beast-first-build/#findComment-1589268
imo that motherboard is way overpriced for what it is. i would either get a cheaper mobo like a maximus hero or a GD65 or go for socket 2011, also i find 128 gb ssd even for casual use isnt really enough would probably recommend 256gb.
but yeah hard to know what to suggest, you havnt listed what the system will be used for.
PC: Corsair 900D | Corsair AX860 | Maxmius VI Hero | i7 4770k | Corsair H100i | 16GB Corsair Vengeance Pro 2133 | Sapphire Radeon 7950 | Samsung 840 Pro 256GB | Win7 X64
HTPC: Silverstone GD05 Black | Corsair VS350W | AMD A6 5400K | AsRock FM2A75-PRO4-M | Corsair Vengeance 2x4GB DDR3 1600 | Samsung 840 128GB | WD Black 4TBx2 | Leadtek Winfast DTV2000DS | LiteOn BD\DVD-RW Combo | WIN7 x64/XBMC
https://linustechtips.com/topic/119218-beast-first-build/#findComment-1589304
If you are getting a 840 Evo get a 250GB or higher. The difference in performance between the 120GB and higher capacities is quite significant.
i know but im not really concerned about loading or start up times anythings better than the setup im using now
https://linustechtips.com/topic/119218-beast-first-build/#findComment-1589899
Ok you could definitely get a lot more by dumbing down things like the motherboard the extreme is really not worth it unless you are doing stuff with LN2.
yeah i got it because the OC capabilities and i might eventually bump up to 4 way SLI so the pci slots are useful
https://linustechtips.com/topic/119218-beast-first-build/#findComment-1589904
The OC capabilities? any z87 board gets basically the same OC most of the time if the chip has it, also 4 way SLI does not scale well you get about 5% more performance from each card after 2.
https://linustechtips.com/topic/119218-beast-first-build/#findComment-1589910
i like the naga because the keys on the side are great for mmos and fps's, i like the kraken for gaming because of the ear cups and mic ( I use a pioneer hdj-2000 referance headphones for editing), and the deathstalker ultimate is just for the switchblade ui
https://linustechtips.com/topic/119218-beast-first-build/#findComment-1589914
Do your thing bro
https://linustechtips.com/topic/119218-beast-first-build/#findComment-1589923
i know on both ends but i might do it later down the line, and the extreme comes with an OC panel you can put in the case, and preset OC's if your not satisfied with your performance you can quickly turn one on then off and it was only like $10 more than the formula so i figured i might as well
https://linustechtips.com/topic/119218-beast-first-build/#findComment-1589937
$10 more than the formula 0_o ok then get it but I would sell those 780's and get a new set of cards for SLI instead of doing 4 way SLI later on.
https://linustechtips.com/topic/119218-beast-first-build/#findComment-1589967
yeah it was on amazon this morning, when i just looked a minute ago it had changed but still not tht much more like 50 bucks more and yeah ik about the cards im just trying to future proof as much as i can
https://linustechtips.com/topic/119218-beast-first-build/#findComment-1590000
well for 1080P surround atm 2 780's is a good bet specially for 120Hz monitors.
https://linustechtips.com/topic/119218-beast-first-build/#findComment-1590013
