Currently my friend has been bugging that i am able to get more higher fps in games but i dont know how, he says he watched other people with the same specs as me play and get alot of fps.
I Was wondering why and i thought it could be the Ram speed since its set to 2133mhz in the bios for some reason. Every time i put it on a frequency at 3200, my PC crashed.
Here is my PC part: https://uk.pcpartpicker.com/list/Hz67CL
Here Is also my benchmark: https://www.userbenchmark.com/UserRun/27845311
I Do have to say, Currently my GPU is slotted in the 4x PCIE slot and not the top one which is a 16x, reason for that is because it wont fit for some reason, i will probs have to buy a verticle gpu mount but would a 16x give me more fps ? and if so how much?
https://linustechtips.com/topic/1191980-ddr-speed/
If the GPU is slotted in the 4x PCIe slot it will be bottlenecked severely. I highly recommend trying to install the GPU in the 16x slot.
Please mention or quote me if you want a response. :)
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
https://linustechtips.com/topic/1191980-ddr-speed/#findComment-13583383
16x will give you an approximate 30% more performance
Your missing out on alot mate
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1191980-ddr-speed/#findComment-13583693
  • 2 weeks later...
30 minutes ago, OCrax said:
Does anyone know a GPU mount i could get though? i accidentally bought a Lian Li 011DXL with is... large
purely my mistake @TofuHaroto
What do you mean by gpu mount like a pcie riser with a bracket or what ?
Build Log:
https://linustechtips.com/topic/1191980-ddr-speed/#findComment-13625159
5 minutes ago, OCrax said:
Yh, like my case is a Razer Lian Li o11 but idk what verticle gpu mount to buy or which one fits into my case @TofuHaroto
Do you want to vertical mount it or are  you forced to for some reason ? 😅
Edited by TofuHaroto
Build Log:
https://linustechtips.com/topic/1191980-ddr-speed/#findComment-13625218
Just now, OCrax said:
Im kinda forced to do it and i want to do it since it looks nice. but mainly the reason is i cant fit my GPU in the first slot as for some reason my sata socket wont allow my GPU to slot in :(
If your case supports vertical mount ( which it does if I remember correctly) just buy a riser and then there should be a normal GPU brackets on the case just vertical and you use the riser cable to slot in the GPU then you screw the GPU with the vertical bracket and that it
The same way you would install a normal GPU but vertical lol
Build Log:
https://linustechtips.com/topic/1191980-ddr-speed/#findComment-13625238
