10 minutes ago, Dennis Tech Tips said:
So I have a i5 9400F and looking to cool things down. What do you recommend?
Any of the $25 4 heat pipe 120mm coolers
Scythe Fuma 2 if you plan to keep it into the next build and you can find one for $50
