1 minute ago, Darpyface said:
Reset your BIOS, you can do this by turning off your PSU then taking out the round battery on your motherboard then waiting ~10 minutes. Then put the battery back in and power it up and your BIOS should be reset.
Ohhhhh, I'm supposed to wait 10 minutes? I was only waiting about 4, sure I'll try that in the morning. Really wish there was a thing to click in the bios or a button to do this type of stuff
https://linustechtips.com/topic/1191473-cpu-issues/#findComment-13580101
This should be the absolute standard on higher end motherboards. A physical bios reset button. How on earth no manufacturer manage to figure this out is beyond me.
https://linustechtips.com/topic/1191473-cpu-issues/#findComment-13580107
Given how often I need to clear the cmos, I would happily swap my current board for one with a actual button if one existed
https://linustechtips.com/topic/1191473-cpu-issues/#findComment-13580117
3 minutes ago, Darpyface said:
They do exist and are fairly common for higher end boards like this
Well dang, I've been all over asus's website, never saw one that had one,but I have been known to be borderline blind to things that are front and center, 😋 this one isn't even too expensive, maybe I'll pick this up when I get a rx 5700 later this year
https://linustechtips.com/topic/1191473-cpu-issues/#findComment-13580150
