Hey All,
In 2018, I Bought a Supermicro Brand Workstation to use in our Architecture Company. The entire purchasing process was based on a dream.
With the System I wanted to set up, four people should be able to use different desktops with modelling and rendering.
I bought Openstack GPU Virtualization Software and Zero Client Remote Access Connection Device with the suggestion of a friend to make this possible. This Software and Hardware enabled Four People to Connect at the Same Time, but they could not process Modelling or Rendering.
Immediately After I Virtualized the Machine with VMware, but in this case I had to partition the Hardware to users and they could only use the partitioned hardware which is assinged. I gave up as this situation reduced productivity. My hopes were exhausted, I took a break from my project.
I watched a video published by Linus this year and this inspired me. Then I returned to my project and tried a strange software called Aster. In fact, the System works as I want, but I am strangely facing freezing errors here. Also I am attaching a benchmark test result.
My research continues to take the project to a higher level, but in this process, hardware parts already are worn out :).
Can those who have this type of experience share their knowledge with me on this subject? I am completely open to suggestions.
I'm new to the forum, I hope I haven't created this content under a wrong Topic. Thank you for your understanding.
Stay healthy.
Budget (including currency): 21.952,00 $
Country: TURKEY
Games, programs or workloads that it will be used for: 3DsMax, AutoCAD, Photoshop, Corel Draw, V-Ray for 3DsMax
Parts List
  • Haswell 14C E5-2683V3 2.0G 35M 9.6GT/s QPI X 2
  • 16GB DDR4-2400 2Rx4ECC REG DIMM X 8
  • Micron 1100, 256GB, M.2 22X80mm, TCG-E SATA 6Gb/s 0.25DWPD
  • Samsung SSD 860 Pro 512GB X 2
  • Seagate 3.5" 2TB SATA 6GB/s 7.2K RPM 128M Megalodon
  • NVIDIA PNY Quadro P4000 8GB GDDR5 PCIe 3.0 - Active Cooling X 2 (Can Apply Addition Up to 4 Graphic Cards, I do Have 2 Quadro P4000 Extra)
  • OS: Windows 10 Pro
https://linustechtips.com/topic/1191370-unfinished-system-help-needed/
Is that in Turkish dollars and is your intention be "build a new PC with two VMs"?
Specs: Motherboard: Asus X470-PLUS TUF gaming (Yes I know it's poor but I wasn't informed) RAM: Corsair VENGEANCE® LPX DDR4 3200Mhz CL16-18-18-36 2x8GB
            CPU: Ryzen 9 5900X          Case: Antec P8     PSU: Corsair RM850x                        Cooler: Antec K240 with two Noctura Industrial PPC 3000 PWM
            Drives: Samsung 970 EVO plus 250GB, Micron 1100 2TB, Seagate ST4000DM000/1F2168 GPU: EVGA RTX 2080 ti Black edition
Hey There, Currency is USD. Because of unstable currency in our Country we are buying technological stuff based on USD every time. My Intention is to build a new WorkStation with Multiple Desktops could use mentioned Programs at the same time with a software help that partitions the needs of users like a Ai or similar.
Budget and Parts are mentioned for Existing System. First of all I need to get this possible on the existing WorkStation after that I will Build the new one. I am hesitating the risk of fail again. I need to see that is working well first on the existing system.
