Quick question about pc building
Go to solution Solved by Matty2048,
a wooden table will do fine and as long as you touch a plugged in but powered off psu case (thats for the anti-static) occasionally should be fine.
Hey everyone sorry if this is on the wrong section (couldn't really decide where to post it) anyways a while back I asked here if I need an anti static braclet and The answer was no ,all is good and I delayed my build as I couldn't buy the parts because of covid etc etc
Now I just want to be 10000% sure before building it is whenever I watch a build guides (just for fun) they say I must have an anti static braclet and a mod mat
Now is the mod mat necessary as it's a little expensive for me lol and I already have a wooden table so would that be good enough ?
And thanks in advance
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1191327-quick-question-about-pc-building/
If you judge a fish based on its ability to climb trees it will go its whole life thinking its a failure.
Alright well thank you so much :)
Build Log:
