Im having trouble with my FPS
i cant play a game with out having the worst fps drops please help
BENCHMARK REPORT
SATURDAY, MAY 9, 2020 12:24 AM
PERFORMANCE
FPS min
18
CPU min
21 ms
GPU min
13 ms
FPS avg
32
CPU avg
32 ms
GPU avg
23 ms
FPS max
46
CPU max
56 ms
GPU max
46 ms
Total frames: 2060
SYSTEM INFO
CPU:
Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz
GPU:
NVIDIA GeForce RTX 2060 SUPER
GPU Driver Version:
445.87
RAM:
16330 MB
VRAM:
8192 MB
VRAM Used:
2442 MB
OPTIONS
VIDEO
Display:
LG TV
Window Mode:
Fullscreen
Resolution:
1920 x 1080
Resolution Modifier:
100%
Refresh Rate:
60 Hz
FPS Limit:
Off
Field of View:
100%
HDR:
Off
GRAPHICS
Graphic Preset:
High
Adaptive Quality:
Off
Anti-Aliasing:
High
Character:
High
Character Texture:
High
Clouds:
High
Clutter:
High
Depth of Field:
High
Environment:
High
Fog:
Medium
Reflections:
High
Shadows:
High
Ambient Occlusion:
High
Terrain:
High
Textures:
High
Water:
High
the graph is here
ok i, installing it now i will inform you on what happens next thanks anyways
1 hour ago, Chabax said:
445.87, this is ur problem, this version clears cache every few sec whic gives stutter, download 445.98 version https://www.guru3d.com/files-details/geforce-445-98-hotfix-driver-download.html
it helped for a while but then i saw that my cpu is actually gonna burn i have 100% utilization even on low sittings it did up the fps but my CPU is struggling HELP!
I have tried everything updating my bios updating my drivers , overclocking the rtx and ive tried overclocking the cpu since it can only go to 4.20hz which is not really overclocking
But nothing works , either im running my game smooth and my cpu goes to 90+ heat (Celsius) and my cpu load is 100% i dont know what to do i need immediate help you guys!
