I need help
Go to solution Solved by Lurick,
Just now, Radoo said:
i want to format the hdd
I would still unplugg it because Windows has been known to try and install bits on other drives during install.
After you do the install you can plug the drive back in, boot off the SSD install (set it to be primary boot priority in BIOS) and then use Disk Management to format the drive after.
easeUS todo backup will allow you to copy a drive to another drive. How big is the SSD, and how much space have you used up on your hard drive?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1191237-i-need-help/#findComment-13578138
If you want to start fresh:
Download the installation creation tool from here:
https://www.microsoft.com/en-us/software-download/windows10
Point it to a USB
Shut down your computer and disconnect the HDD
Power on and it should boot from the USB, otherwise go into BIOS and set the USB to be the first boot device.
Go through the install prompts.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1191237-i-need-help/#findComment-13578139
Point it to a USB
https://linustechtips.com/topic/1191237-i-need-help/#findComment-13578149
Prior Build Log/PC:
https://linustechtips.com/topic/1191237-i-need-help/#findComment-13578156
THANKS A LOT!
https://linustechtips.com/topic/1191237-i-need-help/#findComment-13578165
