Cpu Running at base speed
Go to solution Solved by Jurrunio,
How much did you undervolt? Make sure turbo boost is still enabled
Desktop benching:
The 8300H is a 4 core 8 thread CPU. You disabled half of your CPU. It is only showing 2 cores 4 threads now.
Open msconfig and clear the number of processors box. Reboot so Windows can find the rest of your CPU. The MHz should be OK after that.
I got the box unchecked but it is still running at base speed. Would you know why?
20 minutes ago, Tylergamer120 said:
How would i check if turbo boost is still enabled i can't find a setting for it in the hp bios
Intel XTU
Desktop benching:
