Will this sound setup work?
Solved by seabass9990,
8 minutes ago, XSovereign said:Sorry to clarify, the Aux out (which outputs the mic's recorded audio) on the Quadcast to a 6.35mm Line-in.
I will tell you right now that that mixer will not make your audio better in any way shape or form, so if it is a usb mic I encourage you just to plug it in through usb, besides using adapters and making connections like that is a temporary fix not a permanent solution.
