SetFSB help
Solved by Poet129,
10 hours ago, ShrimpBrime said:I had read there's 2 IC PLL chips on the board. Is that true?
On 5/7/2020 at 7:14 PM, ShrimpBrime said:Hey is this the correct PLL?
https://www.alldatasheet.com/datasheet-pdf/pdf/446250/IDT/932S421BGLF.html?
This other PPL which is on the board is in SetFSB when I have time I will test this for further results.
