Hi Everyone,
I've had issues with my computer ever since I've had it. The main issue I've been having is having green screen on my monitor which is fixed by turning it off and on again. And after installing a new driver today after that couple of mintues later I had a system crash. Could this just be a bad GPU? I have heard issues with the 5700 XT but I'm worried that my GPU could be broken on its way out. The green screen happneds every couple of weeks. Any ideas what could be causing this? Any help would be appreciated. My specs are below if that helps.
Specs
CPU: Ryzen 7 2700x
GPU: RX 5700 XT
RAM: 2x 16 3000mhz
1Tb Hard drive
250Gb SSD.
https://linustechtips.com/topic/1189063-green-screen-and-system-crashing/
2 minutes ago, Sawyer11 said:
Hi Everyone,
Specs
CPU: Ryzen 7 2700x
GPU: RX 5700 XT
RAM: 2x 16 3000mhz
1Tb Hard drive
250Gb SSD.
whats your psu amd how old is it
is that gpu new or used
do you have the latest firmware your gpu
and what cable are you using for the monitor and how old is it
Phone: Pixel 3a (Purple-ish).
Build Log:
I am using the corsair vs 650
The GPU is new.
I don't have the latest firmware.
I am using HDMI and the monitor is about 4 years old.
update the latest firmware.
and try changing the cable
Build Log:
how old is it pleaseeeee
Build Log:
The PSU is new as well. All the parts are new. About 5 months old.
please do this
Build Log:
