Hey just building my fist pc. Went cheap so got a  second hand case with a prime a320m-k and vs450 power supply. Bought a new athlon 3000g , 16 gb ddr4 vengeance pro and a 250 ssd . All wired in went to power it up and have no souce detected on sreen. Iv tryed reseating ram, 1 stick at a time in bith slots still no signal. Can anyone help at all
https://linustechtips.com/topic/1188342-help-with-3000g/
that power supply is pretty bad.
you need a bios update to run the 3000g with the motherboard
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1188342-help-with-3000g/#findComment-13556633
I actually just ran into the exact same issue.
ASUS PRIME A320M-K with athlon 3000G trying to get to post but i dont get any video output.
No graphics card, it is just supposed to be a chrome machine.
I downloaded the new bios from ASUS but cant upgrade because I cant get video output.
https://linustechtips.com/topic/1188342-help-with-3000g/#findComment-13583914
  • 2 weeks later...
