So I ordered a bunch of pc parts to start an overkill build. (i9 9900k, 2080ti). The case I purchased (MSI Gungir 100) comes with 3 font intake and 1 rear exhaust, but I am cooling my 9900k with a 360 rad (kraken x72) mounted to the top of the case. Totaling out to 3 front intake and 4 exhaust( 3 being the rad on the top and 1 in the rear). Curious to know if this airflow setup will cause any issues in the future.
https://linustechtips.com/topic/1188200-need-help-with-airflow/
you might want to get something like static pressure fans since that front and top cover looks like suffocation city.
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1188200-need-help-with-airflow/#findComment-13555704
i was thinking of getting a new case with front open airflow and top for 360 rad. Would that be better?
https://linustechtips.com/topic/1188200-need-help-with-airflow/#findComment-13555706
personally, ill prefer those mesh front cases as air restrictions is at its minimal. But if that case is not that restrictive, then go ahead.
CURRENT PC SPECS
https://linustechtips.com/topic/1188200-need-help-with-airflow/#findComment-13555708
