I'm about to order the parts for my PC build could I run a 5500xt gpu with a 2600 or 3400 CPU without severely bottle necking my build my choice was a 3600 but I'm trying to see if I save a bit of money also would like to know if I could pair any of those CPUs with a 590
https://linustechtips.com/topic/1187630-need-help/
You could run a 5500xt or a 590 with a 3600. Probably a 3400 too. I'd stick with the 3000 series. Also I have a friend with a rx 590 and my build with the Ryzen 5 3600 and a GTX 1660 super beats his by a decent amount of FPS. You don't have to but if you wanted to go with a 1660 super for about $15 more it might be worht it to you
https://linustechtips.com/topic/1187630-need-help/#findComment-13552019
I would say go with rx5600xt  and ryzen 3600 is the best choice acc to me
If u can't go 3600 then go with 3500
I would not go with rx590
If u want nvida card then go with 1660 super
https://linustechtips.com/topic/1187630-need-help/#findComment-13552033
11 hours ago, Shreyasb said:
I would say go with rx5500xt  and ryzen 3600 is the best choice acc to me
I'm pretty sure 590 is slightly better then the 1660 super if not I just need to give a very slight overclock
https://linustechtips.com/topic/1187630-need-help/#findComment-13553424
https://gpu.userbenchmark.com/Compare/Nvidia-GTX-1660S-Super-vs-AMD-RX-590/4056vs4033
1660S is better compared to Rx590
Ya u may overclock rx590 to make it equal to 1660S but Rx590 will run way hot compared to 1660S and also u get gddr6 which is also gives some more fps.
1660S beats Rx5500xt
So 1660S is what I suggest
https://linustechtips.com/topic/1187630-need-help/#findComment-13555184
get ryzen 1600 af/ ryzen 2600/ ryzen 3500 and wiht them
5600XT / rx 590/ 1660 super
5600 XT is noticebly better than 1660 super (on rtx 2060 level) if you cant afoor it go for 1660 super.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1187630-need-help/#findComment-13556247
