So I have the NZXT H710i and I’ve put in the ROG Strix X570-E Gaming ATX motherboard. With the case, the front top panel connectors had the USB 3.0 thing coming off. The HD audio and the RGB stuff I think. The thing I’m struggling to work out is that the tiny little cables that connect the front top buttons arnt there. I’m referring to the USB headers. Does my case not have them, or need them to work? It has all the other cables as standard. Thanks 🙏
https://linustechtips.com/topic/1187079-case-help/
The case should just come with them
although for any water cooling build I would have just suggested an 011 dynamic
https://linustechtips.com/topic/1187079-case-help/#findComment-13547865
Return your case case it's probably just a defect and buy the O11 as its way better for water cooling.
Quote me for a reply, React if I was helpful, informative, or funny
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1187079-case-help/#findComment-13547868
