3 minutes ago, Shrek1 said:
For the price you could get
You dont need a windows license, and even when you get one you can get one for about 30usd online.
Laptop: HP Spectre x360 13t, i7 8565u with 16 gigs, 512 gig  nvme ssd, UHD 620 4k
Other laptop: Acer Chromebook cb3 431 with 4 gigs, celeron n3060 with hd 400 and 16 gigs eMMC soon to be a minecraft server?
Remeber to tag people or else they wont see your post.
https://linustechtips.com/topic/1186956-hows-my-system/#findComment-13546870
1 minute ago, ItzCopiouz said:
i already have peripherals, and i dont trust 30 dollar copies of windows, id rather pay the full 120 dollars for it. although that rtx 2080 would be better than my 2070 super. I only trust evga or corsair power supplies, a 650 watt evga one is only like 20-40 dollars more so id rather go with an evga one.
https://linustechtips.com/topic/1186956-hows-my-system/#findComment-13546942
Fine, then overpay 120 dollars. The MWE has been proven to be a very reliable psu, and 30 dollar windows licenses are commonplace to buy.
https://linustechtips.com/topic/1186956-hows-my-system/#findComment-13546952
if the mwe is good then its ok with me but im never going to trust 30 dollar versions of windows.
https://linustechtips.com/topic/1186956-hows-my-system/#findComment-13546956
Ok, you dont even neccesarly need a windows license.
https://linustechtips.com/topic/1186956-hows-my-system/#findComment-13546961
im pretty sure i need a windows license
Without one, you just will have an unverified copy, which means you cant call them for support, change the background and you will have a faint watermark. Also, I've seen verified copies for 100, why the 120 because its not pro.
https://linustechtips.com/topic/1186956-hows-my-system/#findComment-13546984
The 970 Evo drives are great but all of the high end pci-e 3.0 drives pretty much hit the limits of what pci-e 3.0 can even handle, dropping down to like a 5% slower drive that's still a high tier drive can free up enough money for a 2080 Ti or a decent, modern high capacity hard drive. Knocking out all of the RGB and going with like some a NZXT Hue or just a ebay strip lighting kit that will have much more even light than some RGB fans can save you a ton of money for better, higher performing parts as well. Not to mention this system should be significantly quieter although idle temps and peak temps might be slightly higher which really doesn't matter.
As far as the windows license, you don't actually need it. You just get an annoying watermark on your desktop. Most windows 7 keys activate windows 10 and working 10 Pro keys can be bought for $3-5 at most on ebay. If they deactivate, you just buy another which out of the tens of ones that I've bought has never happened. Spend that $100 on games for your new computer instead.
https://linustechtips.com/topic/1186956-hows-my-system/#findComment-13546997
first of all, i dont want that watermark no matter how faint it is, id rather just pay the full 120 dollars, even if i could get a 30 dollar license. i can pay an extra 90 dollars.
https://linustechtips.com/topic/1186956-hows-my-system/#findComment-13547001
Unless there was a price hike, microsoft sells them for 100.
https://linustechtips.com/topic/1186956-hows-my-system/#findComment-13547005
ok whatever. the system you sent me is pretty good. although im still going to get a normal version of windows even if it costs more.
Microsoft makes windows, of course the ones that they sell will be verified and they are 100 usd.
https://linustechtips.com/topic/1186956-hows-my-system/#findComment-13547017
this system is pretty good. although as i said to ItzCopiouz, i will be buying a normal version of windows for which system i get.
https://linustechtips.com/topic/1186956-hows-my-system/#findComment-13547024
yeah i get that its more expensive when buying from microsoft. but i think that its worth the extra price for an official version of windows.
https://linustechtips.com/topic/1186956-hows-my-system/#findComment-13547028
Ok, good luck building your PC!
https://linustechtips.com/topic/1186956-hows-my-system/#findComment-13547034
