It looks like your display resolution and/or app scaling somehow got messed up. Go into the search bar and open up "display settings". Under the scale and layout section, where it says "change the size of text, apps, and other items," change the setting back to 100% if that's not what it's at already. Also check under "display resolution" and make sure it's set to the recommended setting. For my monitor it's 1920 x 1080, but that may be different for a TV (I'm assuming you're using a TV or a very large monitor anyway. It looks very big in the photo.)
I mostly speak from my own past experience from similar problems. My solution may not work for you, but I'll always try my best to help as much as I can. If you want me to see your reply, make sure to quote my comment or mention me @WaggishOhio383, and I'll get back to you as soon as possible.
-- My PC Build --
Ryzen 7 2700x
AsRock B450 Steel Legend
XFX RX 590 Fatboy
Crucial Ballistix Tactical Tracer RGB 16GB 3200MHz
120GB Crucial BX500 SSD + 2TB Seagate Barracuda HDD
Corsair CX650M
Phanteks Eclipse P350x
https://linustechtips.com/topic/1186133-help/#findComment-13540966
