Hello!
Recently I've been thinking about upgrading my pc, in particular my GPU and RAM.
My current pc specs:
Motherboard: Asrock B450m pro4
CPU: AMD Ryzen 3 2200G
GPU: Gigabyte GeForce GTX 1050 Ti
Power supply: Corsair VS450
RAM: Corsair Vengeance LPX DDR4 - 8gb - 1x8GB - 2666 MHz
HDD: Seagate Barracuda 1tb - 7200 rpm
SSD: Kingston A40 120GB
Windows 10 Pro
I was thinking of upgrading my 1050 Ti to an rtx 2060, and for my ram i wanted to upgrade from 1x8 to 2x8GB. But my question is: If I upgrade my GPU will I also have to upgrade my CPU to prevent bottlenecking? Or will my 3 2200G be sufficient for the new graphics card? And should I maybe upgrade some other components in my PC? Maybe the power supply or something?
Thanks!
Luukbeest21
https://linustechtips.com/topic/1186028-pc-upgrade-help/
13 minutes ago, Luukbeest21 said:
Hello!
Windows 10 Pro
Thanks!
Luukbeest21
These days it’s really hard to bottleneck a CPU. If you watch this video by Jayztwocents you’ll see what I mean
He wasn’t getting any bottlenecking issues until he paired a 2080 Super/2080 Ti with an i3. So you should be fine. As for the RAM I recommend 16GB of 3200 MHz RAM at the best price you can afford.
If you’re willing to search and wait a bit Newegg frequently has Shell Shocker sales on that kind of RAM.
CPU: i7 8700K (5.1 GHz OC). AIO: EVGA CLC 280 280mmGPUEVGA XC2 Ultra 2080Ti. PSU: Corsair RM850x 850W 80+ Gold Fully Modular. MB: MSI MEG Z390 ACE. RAM: 32GB Corsair Dominator Platinum RGB (3600 MHz OC). STORAGE: 1TB Samsung 970 Evo Plus M.2 NVMe, 2TB Samsung 860 EVO, 1TB Samsung 860 Evo, 1TB Samsung 860 QVO, 2TB Firecuda 7200rpm SSHD, 1TB WD Blue. CASE: NZXT H510 Elite. FANS: Corsair LL120 RGB 120mm x4. MONITOR: MSI Optix MAG271CQR 2560x1440 144hz. Headset: Steelseries Arctis 5 Gaming Headset. Keyboard: Razer Cynosa Chroma. Mouse: Razer Basilisk Ultimate (Wireless) Webcam: Logitech C922x Pro Stream Webcam.
https://linustechtips.com/topic/1186028-pc-upgrade-help/#findComment-13540157
19 minutes ago, Luukbeest21 said:
Hello!
Windows 10 Pro
Thanks!
Luukbeest21
Well what do you know! There’s great sale on that kind of RAM right now!
https://linustechtips.com/topic/1186028-pc-upgrade-help/#findComment-13540179
On 4/29/2020 at 7:00 AM, Luukbeest21 said:
Hello!
Windows 10 Pro
Thanks!
Luukbeest21
Oh shoot! I just realized I posted the wrong video. This is the one I meant to post.
Sorry about that!
https://linustechtips.com/topic/1186028-pc-upgrade-help/#findComment-13553224
