Long time viewer and lurker, first time posting so be gentle please!
So I've been using Plex for years now and my NAS has been rapidly running out of space and upgrading it is likely to be troublesome (Zyxel 540 NAS) what with numerous USB drives hanging off the main PC I decided now was the time to bite the bullet and build a base Unraid build that can take on what I'm storing now and grow as needs require it.  Originally I was going to use a 2u Supermicro dual Xeon but tweaking the IPMI to try and get the fans within the wife acceptance factor basically showed I'd need to spend a fair chunk on some noctua fans, plan b fell in to my lap in the form of a Dell 730xd which was being scrapped but again WAF kicked in as in fresh air cooling mode dear god that things loud oops!!
I've come up with a rough spec...
ASUS ROG Strix B450-F
Ryzen 5 3600
16GB (2x8GB) Corsair DDR4 Vengeance LPX Black, PC4-24000 (3000)
500GB WD Blue M.2 - Cache/Appdata
Fractal Design Define 7
550W Seasonic PRIME Ultra, Fully Modular, 80PLUS Platinum
All the above is about £650 which isn't bad.  I know I'll need add either an LSI or Dell h310 to add more than 5 drives as I think the m.2 takes one sata connection?  Is there any point to adding a GPU?  At the moment I've got a small i5 running my actual Plex server and that seems to cope with the occasional transcodes that I have but most connections are direct stream.
Out of the Dell there are a number of SAS 4 & 6TB drives which would be handy to use and save on some costs until I could swap them for new drives is that feasible or not?  I did think about using the ECC ram from it but wasn't sure if the board and ryzen would support it?
One other possible plus is, I built myself a new Ryzen 5 2600X with the same board only a couple of months ago would it be better to swap the processors ?
Thanks!
https://linustechtips.com/topic/1185097-unraid-build-advice/
I have modded a good amount of rack servers to be quiet with reistor mods. Pretty easy, works well, gets the system pretty quiest.
Some systems need the gpu to post, and its really nice to have video out when you need to troubleshoot.
You need the sas card, but then it will work fine.
Registered ecc won't work on ryzen.
https://linustechtips.com/topic/1185097-unraid-build-advice/#findComment-13533450
I have looked at that, the IPMI tweaks did make it quieter but at the compromise of the CPU getting a touch toastier.  They're currently passive coolers on a x9DRH-iTF board.  I looked for some 2u compatible coolers preferring noctua but all they do for 2011 narrow ILMs are 4u.  So I'm stuck with the supermicro SNK-P0048AP4, I could change the fan on that to a 60mm Noctua for about £90 all in for the CPU.
I think the biggest noise maker after that is the 3 fan "fan wall" and a wee bit of googling has suggested I can swap these out for noctua (or similar) BUT it can cause heating issues as the replacements wouldn't create enough static pressure (could be wrong here!) about £50 for those.
The big issue for me is it's got to sit in a dining room under my home office desk No where else to move it to where airflow wouldn't then become an issue :( So plan C was to build a new quieter server and either put this one away for when I have room or take a bit of a hit and stick it on ebay for someone who may have the room or no wife to please! :D
DOH!  Honestly hadn't thought of that!  No spare GPUs either as my gaming is all console based these days.
That's a relief, do I need to get SAS converter cables to use them as well or would the cabling for sas card cope?
Oh well was worth a shot!  More parts for ebay! :)
https://linustechtips.com/topic/1185097-unraid-build-advice/#findComment-13533805
that cpu does support ecc memory but it looks like the board does not
https://www.overclock3d.net/news/cpu_mainboard/amd_confirms_that_ryzen_supports_ecc_memory/1
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
https://linustechtips.com/topic/1185097-unraid-build-advice/#findComment-13537758
