I've just built myself a new gaming PC annnd yes it is my first time. These are my specs.
Case: MSI MAG 010 Vampiric
MB: Aorus B450 Elite (AM4)
Thermpaste: Arctic MX-4
PSU: Corsair VS550W 80Plus
RAM: Corsair Vengeance 32GB DDR4-3600MHz
CPU: AMD Ryzen 5 3600
CPU Cooler: AMD Stealth (stock)
GPU: Gigabyte Radeon RX 5700XT OC
My CPU is heating to about 92-100 degrees when I run IntelBurnTest on High. I'm not sure if this is normal as I am using the stock cooler or I did something really wrong. My idle temps sit around 42-45 degrees. I haven't tested any games as I wanted to ensure my system was stable before doing anything significant.
At the moment I have 2 intake fans at the front and 1 extraction at the back. I plan on mounting an extraction fan at the top to improve airflow.
I have tried:
- Repasting the CPU by removing the stock thermal paste = 2 - 3 degrees improvement.
- I then repasted as I was unsure if I did it correctly = no improvement (put a small amount in the middle)
- Reinstalling the cooler = no improvement
I would really appreciate some advice. I thought the stock cooler would do just fine as I never planned to overclock the system.
P.s I haven't overclocked.
https://linustechtips.com/topic/1185089-cpu-overheating-need-assistance/
