You'll most likely want an SFX unit.
https://linustechtips.com/topic/1184014-need-small-sized-psu/#findComment-13525571
pcpartpicker.com
filter for SFX-12v form factor
https://pcpartpicker.com/products/power-supply/#t=10
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1184014-need-small-sized-psu/#findComment-13525573
8 minutes ago, Tadziunia said:
Not really, it's very expensive meanwhile i am doing sleeper pc with limited space :) isn't there any other cheaper options 450w would be okey
I would recommend the following SFX power supply:        https://pcpartpicker.com/product/KMQG3C/evga-supernova-gm-450w-80-gold-certified-fully-modular-sfx-power-supply-123-gm-0450-y1
Hope this information post was helpful  ?,
        @Boomwebsearch
https://linustechtips.com/topic/1184014-need-small-sized-psu/#findComment-13525601
