Soooooo, hi! I've been using my Corsair H80 on my i5-2500k for a while now since the stock cooler wasn't doing its job.
And I still think I'm not getting the temps I'm suppose to, I've seen others using the same setup with temps under 30C.
I've replaced the thermal paste once and still I'm not getting my target temp :(
uZq0BPd.jpg When I took this picture, I was doing absolutely nothing except for skypeing and have 2 tabs open in Google chrome.
https://linustechtips.com/topic/118357-fairly-high-temps-with-h80/
i5 2500k  under 30 on idle? Haha no. That is just wrong. They probably had very low ambient temps.
those temps look reasonable to me. 35 idle is probably about average but 56 under load max is very strong acceptable temp  :lol:
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
Idle temps typically don't change much with water cooling and are dependant on things such as ambient temps. What's your load temp? That's the most important.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
my 4770k on an asus formula board with a coolermaster 120 AIO had higher idle temps (also around the 30c mark) than my 4770k (a different one) on my gigabyte board with the stock intel cooler (which were in the low to mid 20's)
HP something | 5600X | Corsair  16GB | Zotac ArcticStorm GTX 1080 Ti
CaseLabs SM8 | EK Supremacy | UT60 420 | ST30 360 | ST30 240
Gentle Typhoon's and Noctua's and Noiseblocker eLoop's
