So you guys probably answer question like these all the time but. I'm paying for 1 gig interent and hitting speeds of 30 mbps download and 2.5 up. I'm using the modem router cobo thing but that shouldn't be a problem since there is like 1 wall, printer and 10 feet between me and it. I'm using DSL. Just to check I got almost the same results over ethernet too. So what's the problem? Also while i'm here i'm going to upgrade my computer soon and the motherboard will supports 2.5 gig and 1 gig so does that mean that my router and isp are supposed have 2.5 gig support or 3.5 gig support. Another question if your motherboard has 2.5 and 1gig ports if you plug in both you will get 3.5 gig speeds right?
Quote me for a reply, React if I was helpful, informative, or funny
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1183489--/
