Hey there guys,
I have a question about RAM configuration on a threadripper system.
my system is:
gigabyte trx40 designare motherboard
3960x cpu
Trident Z RGB DDR4-3866MHz CL18-19-19-39 1.35V 32GB (4x8GB)
i have the ram clocked down to 3666mhz to match the overclocked infinity fabric (1833mhz).
So....i need more ram for the work i do (Autodesk Maya)...large scenes and so on.
My 2 options as far as i know, i can buy another 4 dimms as the motherboard has 8 slots.
Or sell the 4x8gb that i have, and buy 4x16gb.
I want to keep maximum performance as i game quite a lot in my free time, and ram speed / infinity fabric speed affects FPS in games.
Would there be any difference in performance 8x8 vs 4x16?
Is there anything else i should consider?
Thanks a lot
https://linustechtips.com/topic/1183052-please-help-ram-question-for-trx40/
no difference, though 8x8 could see more difficult to run at higher speeds. further upgrade in capacity will also be more costly.
Desktop benching:
