Onboard audio LEDs
Go to solution Solved by The Flying Sloth,
They have 0 effect, they're just there to look pretty.
Sloth
I apologise if this has been asked before, but I couldn't find anything by poking around.
Do the LEDs on a lot of motherboards that outline the "separated" bit of the PCB for audio actually do anything to help the separation or are they purely for looks? Moreover, if so, would turning them off have a significant effect?
Thanks in advance 😊
--Gas_Mask_
https://linustechtips.com/topic/1182546-onboard-audio-leds/
Thanks in advance 😊
The LED separation is mainly for looks.
Depends on the motherboard, that LED strip *can* be disabled / turned off within the BIOS settings.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1182546-onboard-audio-leds/#findComment-13515598
I wasn't worried about if they could be tuned off or not, I figured out how to do that. I was just mainly curious if they have any effect on the sound or the electrical signaling.
--Gas_Mask_
https://linustechtips.com/topic/1182546-onboard-audio-leds/#findComment-13522698
Sloth
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
https://linustechtips.com/topic/1182546-onboard-audio-leds/#findComment-13522733
A bit of physical separation on the board will help...a little bit.
All the thousands of traces in the different layers on a motherboard crossing each other will certainly cause some electrical interference.
In addition to physical separate, you would IDEALLY also want to have some kind of metal shielding.
Some boards actually have this.
If you disassembly a laptop, because the it is so compact, in some cases, you can see a metal shield over the:
  • Bluetooth modules
  • WiFi modules
  • USB controller (?)
  • Over certain chipsets / SoCs
For an example, Gigabyte has a EMI shield over the audio SoC on their higher end Z390 boards.
Visual Inspection - The GIGABYTE Z390 Aorus Pro WIFI Motherboard ...
Same goes for ASUS on their ROG boards, and AsRock as well..etc, etc.
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/1182546-onboard-audio-leds/#findComment-13522808
Yeah as @-rascal- said.
If the LEDs are illuminating an actual circuit board design like an isolated ground plane they don't help at all directly but may be illuminating something that does.
The layout can be very important, electrically they can be the 'same' as in what a wiring diagram shows.
Like say with a DAC. IIRC digital and analog circuits should have seperate ground planes bonded with a small trace.
images?q=tbn:ANd9GcTZB3gzd4aOiY4x6x0EvF9
A circuit diagram may not show this and technically you could do say one big ground plane or thin traces with complicated long routing, but there can be measurable performance improvements from good routing and layout.
Going way back for a real world example I think they redesigned the Millet tube amp power supply ground plane in a revision and got much better measurements on the power supply.
It's a dark art and insanely complex subject.
https://linustechtips.com/topic/1182546-onboard-audio-leds/#findComment-13522931
