https://linustechtips.com/topic/1182535-pc-case-help/#findComment-13515512
2 hours ago, 0re0 said:
will the nzxt pc fit this mobo without having to remove the white pecice that hides  the cpu
https://www.newegg.com/asrock-b450-steel-legend/p/N82E16813157869
If you're referring to those silver heatspreaders, it should. It could be a little tight, you could go for the slightly bigger H710(better airflow, too)
https://pcpartpicker.com/product/Y3FKHx/nzxt-h710-atx-mid-tower-case-ca-h710b-w1
https://linustechtips.com/topic/1182535-pc-case-help/#findComment-13515823
