Hello I'm planning on upgradeing my 1080p 60hz monitor soon and I don't know a lot about monitors, I've done some research but since it's a pretty big purchase was hoping to get some validation before spending my money.
https://www.newegg.ca/gray-asus-tuf-gaming-vg32vq-90lm04i0-b011b0-31-5/p/N82E16824236980?Description=1440p 144hz monitor&cm_re=1440p_144hz_monitor-_-24-236-980-_-Product
I'm looking at this one atm it's a little bit more then I wanted to spend was hoping 500 or less but it seems to check all the boxes I believe are important(1440p, 144hz, 400 brightness, gsync compatible, non tn panel and a warranty) I was hoping someone could verify this is a good buy and there's not something i'm missing or a much better deal available. Thanks in advance.
https://linustechtips.com/topic/1182036-purchasing-advice/
That monitor exceed your expectation btw.
Selecting monitors should match your current hardware spec, especially the GPU.
https://linustechtips.com/topic/1182036-purchasing-advice/#findComment-13512069
