23 minutes ago, umut255 said:
image.thumb.png.7528d488335a5c6a0666e7fb19eb0f0a.pngimage.thumb.png.7f6194f30084a256e73623e81f617ed4.png
It also does not work when I type in 192.168.1.100 to start ip adress and 192.168.1.200 to end ip adress. what should I do in order for it to work? I am going to open a minecraft server to play with friends.
That makes no sense, the router does not need you to specify the WAN IP Address, its job is to handle that for you.
Main Rig:-
Server:-
well, whats the issue? is your server crashing? do you have the right one in your minecraft server properties? i recently setup a linux minecraft server. the idea behind port forwarding is you have a single unchanging static ip for others to connect to then they connect to your pc's possibly changing ip.
Ip in server properties: your tunnel ip.
start: the static ip
end: your pc's ip.
I use windscribe portforwarding so for me thats
server properties: tun0 ip (vhanges occasionally)
start: static ip (what others need to type to join your server) i assume you set a static ip?
end: my pc's ip adress
a warning: hosting pc cannot connect to the server or itll mess up.
your tunnel ip is not your static. if youre not using a 3rd party port forward, likely no tunnel, also the ipv4 ip in connection info is the "your pc's ip" one.
so try
server properties: pc's ip
start: static
end: pc's ip
hope that helps
main rig:
CPU: 8086k @ 4.00ghz-4.3 boost
PSU: 750 watt psu gold (Corsair rm750)
gpu:axle p106-100 6gbz msi p104-100 @ 1887+150mhz oc gpu clock, 10,012 memory clock*2(sli?) on prime w coffee lake igpu
Mobo: Z390 taichi ultimate
Ram: 2x8gb corsair vengence lpx @3000mhz speed
case: focus G black
OS: ubuntu 16.04.6, and umix 20.04
Cooler: mugen 5 rev b,
Storage: 860 evo 1tb/ 120 gb corsair force nvme 500
backup
8gb ram celeron laptop/860 evo 500gb
Nope, that would be Dynamic DNS. Port forwarding is to allow the computer to determine incoming packets destined for a specific use, allow them through a firewall and FORWARD the packets on to the correct machine on the network.
Quote
end: your pc's ip.
Where did the tunnel come from? This means you created a tunnel in Linux which doesn't help the OP at all unless your ISP is using tunneling to provide the service to you (which still doesn't help OP)?
Main Rig:-
Server:-
did you miss the second half of my post twords the bottom? he didnt say if he used a router static ip adress, or a 3rd party, so i included both incase.the tunnel ip is only cause 3rd party static ip im using.
the part where i said "so try" is what the op needs to try.
@Master Disaster
main rig:
case: focus G black
backup
3 hours ago, dxzone12 said:
personally never seen a router make you specify a range like that. What is the model of your router ?
@Master Disaster
What should I type to the start and end ip adress?
Never seen that before.
I suppose your IP twice your running the server from. Always can try.
Maybe if that doesn't work, try your IPV4 address and public IP.
First watercooled System
Build Name: White Knight
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: Corsair Clear
PSU: Lian Li Edge 1000W
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: Beacn Mic
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS/Gamer Advantage Liquid
Camera: Razer Kiyo Pro/OBSBOT Meet SE
9 minutes ago, umut255 said:
Ipv4 address as 192.168.1.109?
DON'T TELL ANYONE! Except people you trust.
start menu, cmd, type "ipconfig"
Then you'll see you're IPV4 address and public or go ipchicken for you're public.
Yes. See if it works.
The port forwarding like I said try both start and end with you're IPV4 address if it doesn't work do start with yoru IPV4 then end with public.
However the first should work fine. I have a MCserver too and use IPV4. Public for out of network people as they need that to connect either way through direct connect to the server.
The command prompt I mentioned is just to see IPV4
I tried
IP        Ipv4   IP   Ipv4
Ipv4    IP       IP   Ipv4
none worked. Is there anything else that i can do?
Wait...is virtual server you're port forwarding area?
on my router virtual server is something different.
Do have just a port forwarding tab.
If you're not playing on LAN try leaving it blank.
IPV4 only as well. Thats how mine runs
I couldnt see any port forward options. Is it because this is a wireless modem?
No, cause mine is too. I'm hard wired now but before it was wireless modem/router.
You should be on network settings>NAT>port forwarding and use you IPV4
Leave Translation ports blanks.
what should i do now?
You're still in advanced.
Network Settings
Here this may help you better than I can explain cause I don't have that modem/router choose yours and follow instructions to port forward it should straight forward though.
https://portforward.com/huawei/
my router is not in the list... Its model is b535-232
