27'' 1080p monitor
TrainFan475
Any good monitor recommendations under $200 for 1080p, 27 or so inches? 60-75Hz is fine, but if 144hz is possible that would be awesome. Preferably ips but TN if it's a lot cheaper. I don't really care about response time as long as its 5ms or under. I'm currently getting a stiff neck by hunching forward to see my 19'' 1600x900 panel.
CPU: Ryzen 5 5600x  | GPU: GTX 1070 FE | RAM: TridentZ 16GB 3200MHz | Motherboard: Gigabyte B450 Aorus M | PSU: EVGA 650 B3 | STORAGE: Boot drive: Crucial MX500 1TB, Secondary drive: WD Blue 1TB hdd | CASE: Phanteks P350x | OS: Windows 10 | Monitor: Main: ASUS VP249QGR 144Hz, Secondary: Dell E2014h 1600x900
Hard to squeeze 144Hz in an under 200$ budget in my experience.
Just looking though Amazon is your best bet anything AOC, HP, ASUS, MSI should be pretty good. As for the price you might consider downsizing to 24 inchs i mananged to get this in december for £135 and i dont have any complaints currently though youll probly have a decent wait for any to come into stock a few weeks most likely
Ryzen 3700x, RTX 3080, 32GB Ram 2x16gb Corsiar Vengance LPX ddr4 3600,2TB 970Evoplus m.2 nvne, MSI B450-A PRO MAX, Windows 10 64 bit ,AOC 1440p 32 inch 144hrz, AOC 1080p 24 inch 144hrz, Corsair RM850 power supply
To get a 1080p 144hz 27" monitor under $200 is gonna be tough.
The best i could find were these three monitors which are 1080p and 27" but only 75hz:
AOC G2778VQ 27" 1ms Full HD Freesync Gaming Monitor
Iiyama G-MASTER BLACK HAWK
Iiyama Prolite X2888HS-B2 (this one's actually 28")
This one is JUST under $200 but the response time is pretty high:
Sceptre C275B-144RN
If you're willing to go over your budget by only $30 then you can get:
ViewSonic VX2758-P-MHD
which is 1080p, 27", 144hz and only 1ms response time
(sorry that a few of these are in uk pounds but im british and i cba to change the money to dollars)
