Preface: this is my friend's computer, I'm posting here for him with all of the information that he knows.
Every time he turns his computer on, the fans go on and the hard drive whirrs, but there is no diplay output with both the iGPU and the dedicated GPU.
He has tried reseating the ram, reseating the GPU, resetting the BIOS, and cleaning everything, and the monitors + cables are confirmed good.
He has never done any overclocking
He doesn't entirely know what he has on his system, so this is the most lacking part:
Intel CPU circa 2016 w/stock cooling
MSI Mobo circa 2016
MSI GTX 1060
8GB DDR3 team ram
EVGA 600B 80+ Bronze
CPU: AMD 3600X
GPU: Nvidia 3070 (planned)
motherboard: MSI B500-A PRO
memory: G Skill Ripjaws V 2x8 GB 3600Mhz CL16
PSU: EVGA B3 650@
Case: NZXT H510
wireless network adapter: intel ax200
https://linustechtips.com/topic/1181088-system-wont-boot/
The best thing to do in these kind of issues is unplug the unnecessary hardware. Basically keep only:
-CPU and CPU cooler
-One memory module (he could try different DIMM slot)
-Front panel connectors
-CPU power
-24 PIN Power
Tell him to unplug everything else (graphics card, optical drive, HDD/SSD, case fans etc).
If it still doesn't work, he can remove the motherboard from the case and test again just to be sure there's no short caused by the case. If he takes to mobo out, he will need to start the PC with a metal object (like a flat head screwdriver) by shorting the power switch pins on the motherboard.
https://linustechtips.com/topic/1181088-system-wont-boot/#findComment-13505012
