Hey everyone,
I would like to have your guys input on a dual pc build for streaming. If you guys could help me out, it would be appreciated. I don't know what to expect for a budget so, the lower end is likely closer to what I could pay for. I don't need rgb, or anything fancy. I don't need a monitor or keyboard and mouse. A case is likely, or if I need one.
Thanks
https://linustechtips.com/topic/1180597-new-streaming-build-help/
Just now, Viper9 said:
What do you mean by "dual PC build" two PCs in a single case? If so, why?
No, I've heard lots of people use two PC's for streaming. One to play on and the other to do the encoding
Just now, YT_DomDaBomb20 said:
How much streaming do you plan to do
I'm not sure, I'm kinda just starting out.
Once a week?
First PC they both use same case + psu and you’ll want an elgato in you pcie slot
Gaming pc
Gaming pc
Thank you
Gaming pc
Sry in case I want clear I meant the top is streaming bottom is gaming the streaming goes on the itx mobo part of case, I think it’s on the bottom. And the elgato will make the streaming better it will cost a good amount though
There is no need to build two pc's for that. A 3700X and 5700XT for example would be fine for gaming/streaming. Or if you go with an Nvidia gpu like the 2070 Super you can use Nvenc to do the encoding. That uses the gpu rather than cpu.
Gaming pc
WFT ? A 1200W psu ? You serious ? And for $2050 he can do a hell of a lot better.
This would kick the crap out of that suggestion above for less money.
You don't have to spend $2000 though.
PCPartPicker Part List
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor  ($434.00 @ Amazon)
CPU Cooler: ARCTIC Freezer 34 eSports DUO CPU Cooler  ($47.22 @ Amazon)
Motherboard: Gigabyte X570 AORUS ELITE WIFI ATX AM4 Motherboard  ($209.99 @ B&H)
Memory: Team T-FORCE VULCAN Z 32 GB (2 x 16 GB) DDR4-3200 Memory  ($129.99 @ Newegg)
Storage: Team MP34 1 TB M.2-2280 NVME Solid State Drive  ($136.99 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Amazon)
Video Card: EVGA GeForce RTX 2080 SUPER 8 GB BLACK GAMING Video Card  ($699.99 @ Newegg)
Case: Fractal Design Meshify C ATX Mid Tower Case  ($99.95 @ Walmart)
Power Supply: Cooler Master MWE Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Best Buy)
Total: $1908.11
Generated by PCPartPicker 2020-04-19 16:34 EDT-0400
Power Supply: Thermaltake Toughpower GF1 PE 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($119.99 @ Amazon)
Total: $1928.11
Generated by PCPartPicker 2020-04-19 16:31 EDT-0400
I appreciate the help. It sounds like a great build but Is there anywhere I could possibly bring down the cost?
Total: $1928.11
I'm starting from nothing and I don't think I can afford it.
A cheaper option would be something like this.
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($174.15 @ Walmart)
Motherboard: MSI B450-A PRO MAX ATX AM4 Motherboard  ($99.99 @ B&H)
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3200 Memory  ($69.99 @ Newegg)
Storage: Team L5 LITE 3D 480 GB 2.5" Solid State Drive  ($59.99 @ Amazon)
Video Card: MSI GeForce RTX 2070 8 GB VENTUS GP Video Card  ($409.99 @ B&H)
Total: $1064.04
Generated by PCPartPicker 2020-04-19 16:47 EDT-0400
https://pcpartpicker.com/list/84py9G
That build would let you stream and is priced $1,340.03
I agree with Lee, though I doubt I would have said it so forcefully.  You do not need 2 PCs to stream, that was the case once, but not anymore.
This build is cheaper than build one suggested above, hope it is in your budget.
Total: $1064.04
Can that psu support 2 systems I only said the revolt x because that’s the only one I know that has a port for 2 motherboards
