Have you downloaded the driver from Logitechs website?
Also, what's the problem with it? Are there functions you can't use?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1180355-help-me-guys/#findComment-13498968
27 minutes ago, RPG_Killer said:
the scrol weel keeps jumping
What do you mean by jumping? Skipping lines like when you are in game and you want the second item but it jumps to the third or fourth, that would be a feature not a bug, as they say it. Usually this can be disabled and is meant for office use only.
https://linustechtips.com/topic/1180355-help-me-guys/#findComment-13499039
