Where does it say that? If system32 is in fact dleted then the easiest way to fix it would be to do a reinstall of windows.
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
https://linustechtips.com/topic/1180330-system32-is-missing/#findComment-13498710
2 minutes ago, jamiepac18 said:
It said that when I booted up the computer and how do I reinstall windows sorry?
Its the same proccess as installing windows. You can find a tutorial on youtube.
A quick overview would be you get a usb drive and download windows media creation tool and run the setup on another pc. Then you take the USB plug it into the laptop, start it and enter bios. Then select the USB in the boot menu. Save and restart. Then you just go through the install instructions which is very straightforward.
My Rig
 Peripherals
https://linustechtips.com/topic/1180330-system32-is-missing/#findComment-13498725
If you have anything on the hard drive, recommend backing them up, there are also several ways to restore operation to the OS, one of which via use of a USB drive, known as a installation media, make sure you have your CD key with you, if it ask for it during install.
Also make sure there is nothing on the thumb drive, it will formatted to be a boot partition. In otherwords you will lose the data on the thumbdrive.
https://www.microsoft.com/en-us/software-download/windows10
As for the other option, is to reset the PC entirely... Which can be done under Settings > Recovery > "Reset This PC" with the Get Started button. Pic below.
https://linustechtips.com/topic/1180330-system32-is-missing/#findComment-13498738
The main question is - what do you make before that happens. Fixing bug by reinstalling Windows, if you (for example) start cleaning system files again, is pointless. Of course you must do it if your system32 is missing, but maybe (just guessing) you somehow moved it to some subdirectory. Don't know is it even possible, but who knows.
Anyway, screenshot shows that your system boots, nothing wrong. So where is that info about system32 missing?
https://linustechtips.com/topic/1180330-system32-is-missing/#findComment-13498768
