Looking For A Better Cooler Solution
Solved by ftahir192,
You have only 165mm cooler clearance which means that most big tower coolers will be right against the panel.
The NH-D15 will literally be touching the glass panel so that's probably a no. The dark rock pro 4 will leave you a few mm gap.
If you want something that isn't as massive as these two but still performs exceptionally well, look at the Scythe Fuma 2.
