hi,
so i'm here because i'm searching and i just cant find listings for what i'm looking for on ebay ect.
i'm looking for a graphics card cooling (the heat sink and fans housing and all or in short a gpu without the card it self)
i don't really care which card it just needs to be mostly black (or rtx reference cooler)
i was hoping people could find a listing for me
thank you that's all.
https://linustechtips.com/topic/1180143-graphics-card-cooler/
There are also water cooling brackets for AIOs.
https://linustechtips.com/topic/1180143-graphics-card-cooler/#findComment-13497437
There is also an option for water-cooling the gpu. So far, the options im aware of is from nzxt and id cooling (i own one :3 )
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1180143-graphics-card-cooler/#findComment-13497440
