CPU: Ryzen 5 2400G: 11,500৳
Motherboard: GIGABYTE AMD B450M S2H: 5,999৳
RAM: 2x Thermaltake H-ONE 8GB 3000MHz: 3,400 x 2 = 6,800৳
SSD: Gigabyte UD PRO 120GB SSD: 2,250৳
HDD: Western Digital Blue 1TB HDD: 3,600৳
Case: XTREME 950 ATX CASING WITHOUT POWER SUPPLY: 1,150
PSU: Corsair CV450: 3,400৳
Total: 34,699৳/$410.22
This was the closest I could get without compromise. Didn't want to get a list with Ryzen and slow/single channel RAM, or a list without SSD, unreliable PSU etc.
You can add a used GPU down the line and increase performance. PSU is decent so should be able to handle it, 16gb 3000MHz ram is good for a few years of high-end gaming so you don't need to upgrade RAM for a long time.
https://linustechtips.com/topic/1179939-need-help-deciding/#findComment-13496054
Thanks a lot of the advice
What if i swap the processor for 3400g and the motherboard for MSI B450M-A PRO MAX AMD AM4 MOTHERBOARD will it be worth it
https://linustechtips.com/topic/1179939-need-help-deciding/#findComment-13496080
Yes, both motherboards are sufficient and 3400g should perform slightly better than 2400g. If you can afford it, go for it
https://linustechtips.com/topic/1179939-need-help-deciding/#findComment-13496084
