Does anyone know if they make fan controllers with RPM readouts, that I can actually turn off the fans with?
I'm gonna try it in a bit to check how warm things get over time, but I think for browsing/ etc I can turn my fans off and passively cool via air rising in my case through my top 480.   I don't plan on doing this 24/7 but I think it'd be a neat science experiment without actually tearing my sidepanel off and unplugging everything.
Before someone asks, I can't control 3 pin fans with my board via AI suite and fan xpert 1.0, so that doesn't work for me either :c
https://linustechtips.com/topic/117949-fan-controller/
http://www.frozencpu.com/products/22295/bus-369/AeroCool_CoolTouch-E_4x_Channel_7_Color_LCD_Touch_Fan_Controller_-_Black.html?tl=g47c17s286#blank
I read the quick little description and it said it allows an "off" mode which I believe is what you are looking for :D
Ryzen 1600@3.8ghz / 16gb 2400mhzASRock B350 ITX / Gigabyte RX 470 4gb / 256gb M.2 / SG13B-Q / Corsair 450w
https://linustechtips.com/topic/117949-fan-controller/#findComment-1573244
ty :)
I wonder if this one does the same, and it has 6 channels instead of 4 :o
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=36_48&products_id=37478
it doesnt say it does, but it has that little power button+ manual fan control so I wonder...
https://linustechtips.com/topic/117949-fan-controller/#findComment-1573264
"The LCD touch screen has seven colors to chose from so you can match your theme. The CoolTouch even allows an off mode so you can go dark when wanted."
I dont think the "off" command is for the fans; rather the LCD function.
      4+ Years on Steam - Profile Name: Nimbus ~l~ Microsoft Windows 8.1 Pro 64-bit ~l~ ASUS Z87 Pro ATX Intel Motherboard ~l~ Intel Core i7 4770K 3.5GHz Processor ~l~
EVGA NVIDIA GeForce GTX 780 Superclocked w/ACX Cooler 3072MB GDDR5 Video Card ~l~ Crucial Ballistix Sport 16GB DDR3-1600 Dual Channel Desktop Memory Kit (Two 8GB Memory Modules) ~l~
Samsung 840 EVO 120GB Internal Solid State Drive (SSD) ~l~ Seagate Barracuda 2TB 7,200 RPM Internal Hard Drive ~l~ Corsair RM Series 750 Watt ATX Modular Power Supply ~l~ NZXT Crafted Series Phantom 410 Mid Tower ATX - Black
https://linustechtips.com/topic/117949-fan-controller/#findComment-1573273
Welp, I tried lol
https://linustechtips.com/topic/117949-fan-controller/#findComment-1573276
  • Power on/off for each individual channel
Wouldn't that be for the fans?
https://linustechtips.com/topic/117949-fan-controller/#findComment-1573288
I didnt read the features section........ but yes that would be what you are looking for.  So good call after all tryphaa
https://linustechtips.com/topic/117949-fan-controller/#findComment-1573306
@Nunnya Business @tryphaa  Do you think if I messaged performance pc's about this: http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=36_48&products_id=37478
And asked if it could turn fans off, if they'd test and tell me?
If it can't I can just get the one you guys linked
https://linustechtips.com/topic/117949-fan-controller/#findComment-1573321
I would say try thier Live chat....... you will usually get the same information, just quicker.
https://linustechtips.com/topic/117949-fan-controller/#findComment-1573369
I would, I would also check if frozencpu.com has it too and email them, just to double check. I dont see why you wouldnt be able to turn the fans off at all in the first place with a fan controller.
https://linustechtips.com/topic/117949-fan-controller/#findComment-1573372
Yeah, it's a bit retarded.  My nzxt sentry mix 2 only goes to 40% min speed :/
https://linustechtips.com/topic/117949-fan-controller/#findComment-1573471
I was always under the assumption you could do it, but I guess you learn something new everyday.
https://linustechtips.com/topic/117949-fan-controller/#findComment-1573482
https://linustechtips.com/topic/117949-fan-controller/#findComment-1573494
They messaged me back, said the g-vans one can turn the fans off, and it has 2 extra channels over the aerocool which is nice, since I have 8 fans on y splitters that make them need 4 channels, so I'll have 2 extra if I ever decide to add more fans later on
https://linustechtips.com/topic/117949-fan-controller/#findComment-1579456
Lamptron makes them. You can turn the fans off too.
https://linustechtips.com/topic/117949-fan-controller/#findComment-1579663
The only problem is it's impossible to find in stock :/  they replaced it with the v3 I believe, which the cheapest I can find is 96$ :/
https://linustechtips.com/topic/117949-fan-controller/#findComment-1579735
Yeah they don't make it anymore :(
You can find a lot of these on ebay though, depending on if you want used fan controllers or new lol.
https://linustechtips.com/topic/117949-fan-controller/#findComment-1579999
