5 minutes ago, Ummeli said:
I just bought some parts to set up a new PC. I decided to build a test bench to use it on but just remembered that I will need a power button, is there any way to bridge a board to power it on without a button (until I can get one shipped)
Just short the two power button pins with a piece of metal. A screwdriver would work perfectly.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1178596-power-button/#findComment-13486057
7 minutes ago, haris7saud said:
 this is somewhat inelegant
Desperate times calls for desperate measures hahahahaa
and then use the PSU's power button as the system power button
Or just shut down Windows properly? 🤔 And not like a Neanderthal
https://linustechtips.com/topic/1178596-power-button/#findComment-13486084
