Wanting to upgrade CPU and motherboard
Iam using i5 3570k and msi z77a-gd65
Wanting to upgrade to i7
Do I go with
I7 4770k with either msi z87-gd65 or msi z87 mpower costs £387 to £396
Or should I go with
I7 4820k extreme 2011 ivy bridge
With asrock x79 extreme 4 costs £394 it's for gaming video editing and making music. Thanks in advance
https://linustechtips.com/topic/117817-upgrade-advice/
@Madmecc75
The 3570k is a great all rounder CPU for gaming etc. It isn't really worth upgrading to i7 unless you be doing heavy threaded processes like transcoding/encoding etc?
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
https://linustechtips.com/topic/117817-upgrade-advice/#findComment-1571523
I wouldnt bother and would try and wait for haswell e as none of the options you listed are going to get you any real big jump in performance.
https://linustechtips.com/topic/117817-upgrade-advice/#findComment-1572988
There is no point upgrading to a newer processor for only a marginal performance gain. I would wait for Haswell-E and get a nice 6-core CPU for the price of the 4820K today.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/117817-upgrade-advice/#findComment-1573018
From what I have found out on internet haswell e will have a different socket and at a guess it will cost a bit. I.e if it's DDR 4 ram then I would want to upgrade to that might wait till computec is over and then will find out prices.
Yes mate, that is a great idea and much smarter than upgrading now, especially when having that particular setup.
https://linustechtips.com/topic/117817-upgrade-advice/#findComment-1575277
Pricing will be similar to Ivy-E minus the DDR4 ram.
https://linustechtips.com/topic/117817-upgrade-advice/#findComment-1576510
