https://linustechtips.com/topic/1177747-building-a-pc/
1 minute ago, TheRedBarron said:
There are some warnings at the bottom but they are very vague.
  • Warning!Some AMD B450 chipset motherboards may need a BIOS update prior to using Matisse CPUs. Upgrading the BIOS may require a different CPU that is supported by older BIOS revisions
The msi MAX series cpu come with the corerct bios, so don't worry about that.
  • Note:The motherboard M.2 slot #1 shares bandwidth with SATA 6.0 Gb/s ports. When the M.2 slot is populated, two SATA 6.0 Gb/s ports are disabled.
Exactly what it says. if you put in the m.2 slot, 2 sata ports will be disabled. but there are 4 (I think) other sata ports for you to use anyway.
  • Note:Some physical dimension restrictions cannot (yet) be automatically checked, such as cpu cooler / RAM clearance with modules using tall heat spreaders
It should all fit ok.
https://linustechtips.com/topic/1177747-building-a-pc/#findComment-13479592
12 minutes ago, boggy77 said:
looks good, you've picked good components that are compatible, I see no issues with it.
Agreed.
What are you going to use the build for? You could go with an EVGA 2060 KO and get a nice boost in productivity tasks as it uses the same die as the 2080 - no benefits in gaming though, so something to consider if productivity is part of your use case.
https://linustechtips.com/topic/1177747-building-a-pc/#findComment-13479616
some slight changes:
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($174.99 @ Amazon)
Motherboard: MSI B450 Gaming Plus MAX ATX AM4 Motherboard  ($104.99 @ Amazon)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory  ($84.99 @ Amazon)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive  ($109.99 @ B&H)
Video Card: MSI Radeon RX 5700 8 GB MECH OC Video Card  ($309.99 @ B&H) performs better for a similar price.
Case: Cougar MX330 ATX Mid Tower Case  ($42.94 @ Newegg)
Power Supply: Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($73.98 @ Newegg) better than the GD.
Total: $901.87
Generated by PCPartPicker 2020-04-14 11:52 EDT-0400
https://linustechtips.com/topic/1177747-building-a-pc/#findComment-13479952
