It all started 2 days ago when I was cleaning my pc with a vacuum cleaner. I cleared all the dust and booted my pc. It worked fine until my pc just shut down, it was late at night so I just went to sleep. The secound day I booted my pc and it worked for like an hour or so and just shuted down. I checked if its not overheating, but its not. I cleaned my CMOS, checked my pcu, checked ram and finally decided to change my pcu cable (ac or dc idk how is it called) and it worked for like an hour when my game freeze. I restarted my pc and tryed again. It worked for a little longer and then it just shut down again. And when I boot it up there was a red light shining next to DRAM_LED. Idk what to do anymore, I tryed everything, AND IT STILL DOESN'T F*****G WORK.
MY SPEC
I7 950
12gb ram
Gtx 550 ti
Asus p6x58d-e
https://linustechtips.com/topic/1177702-need-helpdram_led-red/
Alright, well first never clean your PC with a normal vaccum cleaner as it leads to build up of static that let's hope hasn't affected your system. Go ahead and take everything out of the case, power it on with only the CPU and one stick of RAM inside. If nothing happens make sure your power supply isn't the problem by testing it with this trick:
DO you have any compatible hardware you can test it with? It's the only way to isolate the issue to one component, I suspect though that your vacuuming damaged the board and you'll have to get a new one.
Ryzen 7 2700X  ASUS X470 PRO  16GB 2400Mhz Crucial Ballistix SAPPHIRE RX 580  970 EVO  Dark Rock PRO 4  Dark Base PRO 900
https://linustechtips.com/topic/1177702-need-helpdram_led-red/#findComment-13479198
Bro It just turned on I swiched up some ram slots and it turned on
https://linustechtips.com/topic/1177702-need-helpdram_led-red/#findComment-13479216
