Hello everyone!
I would like to ask who does record games on pc. What is the best settings for 1080p60 recording I have a i5-8300h 1050 16gb ram.Mostly I use Integrated Graphics to record my footage because is more practical i think but sometimes I drop frames really much like sometimes 20% on software I use x264 enconder
https://linustechtips.com/topic/1177616-obs-settings/
You should use the NVENC-encoder.
https://linustechtips.com/topic/1177616-obs-settings/#findComment-13478459
Could you give more info. Like what are you recording? Games? External source? You don't have that good CPU, so anything extra running will mean issues if you are going for 1080p60. For streaming the bitrate used for that level is 5000-6000kbps. For recording, many use 4-10x that amount.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1177616-obs-settings/#findComment-13479037
